2005 headlight clip stuck | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter Earthrider
Earthrider
9
The long spring clip on back of the right headlight is stuck… really stuck it seems. Any ideas out there?
Jack
Yes some penetrating solvent and if its the one with the tab get some channel locks and get a good grip on it and put some "hind end" behind it and it should snatch free. About 45 seconds into this video:
Yes the above helps, but at the same time put a flat hand on the headlight and push in hard on the headlight at the same time
your are trying to remove the clip.
Jack
You have to be mean with it. I changed both headlight assemblies and discovered that someone down the line removed both clips on the passenger side. I ordered new clips from Ford (comes as a complete set for both sides) and was told there were very few left. I was able to get everything done.
