Bobwheeler
- Dec 28, 2021
- 2004
Have a difficult to define, intermittent coolant leak in that area. Everything I can see looks good. Road tests are inconclusive. Any hints?
More data: I have changed out the degas (expansion) tank and hose. Found the upper connection broken. Part of the plastic tube came off with the hose. Got it out. Hose reusable. Took it for a 4 mile test drive after filling to between the fill lines. As I stopped in the garage, approx 1 pint (what I added earlier) was discharged on the floor. Drip spot says center of car at about aft end of engine. Next day, after inspection and not adding coolant to approx 1 inch below fill lines, went for same test ride. Stopped in front of garage to avoid mess. Turned it off; no leaks. Put it in the garage; no leaks. No coolant in the car. Visual shows nothing. This is a mystery. Is there a relief valve in the system somewhere? My Tech Service Manual for a 2005 shows a relief valve at the exp tank. I have not bled the high point vent as I never lost more than a cup (8oz) of coolant. Car had been driven 500+ miles with exp tk level down as noted. Filled it to try to do the right thing and now have this mystery. Car will be on a lift 29 Sept. so maybe will see something then. Anybody with a similar situation. Does not make sense to me. Any stories on a bad freeze plug? Thanks.
