E
elaine moore
- 0
- 2004
We have a 2004 thunderbird with about 32000 miles. It was parked for 6 months and now we have these issues. When we stop or are going slow The car dies, we can turn the key and it starts back up. At high speed the rpms will drop to zero and then jump back up the mechanic tells me the car is dying but because of the high rpms it starts up on its own. The issue happens and car restarts so quickly they they can get an error code. We took it to the ford dealer who told us they had to force a check engine light to get an error and that the PCM is bad. They have ordered one but said it could be years before we get it. This same dealer tried to replace the PCM on another thunderbird last year with a non ford part 2 times and never got it to work. They will put the PCM in if I buy one but no guarantee and if it doesn’t work I have to keep paying the labor over and over. I knew there had been issues with the ignition coils so we had all of them replaced the parts they used were not ford. I mention this in case it makes a difference or could be part of the issue. i have received recommendations to clean the mass air flow sensor and to check the throttle position sensor and the whole throttle assembly to make sure it is clean and moves freely. Also to change the fuel filter. I wanted to see if anyone here has any recommendation. Your help is appreciated. Also we are loaceted just north of Charlotte in case you have a recommendation of a mechanic in our area that has experience working on Thunderbirds.
