jbird
- 0
- 2003
have two experiences, two days in a row culminating in a trunk fuse box review. I noticed
1- the fuse box isn't secured down
2- fuse #22 (ignition switch) was popped up, a 40A where the diagram says should be a 20A
I can secure the fuse box, the wires in appear secure.
What causes a fuse to pop up or be unseated?
I plan to go back to a 20A in this slot, I haven't found the right search to tell me if the current fuse it bad but I reseated and my car situation did not improve.
Background:
Experience 1: started car, a trac light, then ABS, then battery lights came on. I turned around (id been a block) and turned off car. Turned ignition back on and horn started honking, turned switch off. What preceded this was warming up car w trunk lid open and seat heaters on. I never do this bc I try to take it easy on the electronics.
Experience two: I put a borrowed odb2 scanner on it (works poorly) and about two minutes into the warm up, the engine died. Tried starting it again and it turned over then clicking. The rest of afternoon just clicking. And I can heart some clicks under hood after I turn key off.
Last four slots on right should be 20,30,30,40 and the fuses used are 40, 20,20,30. Am I somehow reading this diagram incorrectly? Did someone use the wrong fuses? I'm confused.
Since the fuse box is "loose" inside the trunk I wonder if it's a replacement from a different year model.
Background:
