Jim:
I couldn't find on a
search, "top won't go down" , but here's some info for you:
From a guy in Belgium:
"Sometime my
soft top won't react on me pushing the button to put it down. Pretty annoying when I want to benefit from some late season sunshine...
I push the button, and nothing happens (not even the slightest noise of relays or other contact or electric motor). I thought it was a bad contact somewhere, and when fiddeling around on the fuse box, other hood contacts etc it went ok again, until the next day...So I don't know
I have no service point in the area ( I live in europe), anyone has an idea what the problem could be?"
His final response to his own problem was:
"I spent this saturday checking some electrical contacts. I opened (this is not recommended to do if you are not sort of an experienced model builder) and cleaned the
softtop up/down button and the connectors . I had the 'door/booth/hood'-open warning light on too on the dashboard, seemed that the booth open/close contact was misaligned. Now everything seems to work normal again. We'll see how it does over time, but it's okay now."
Another guy: "I have had the top not go up on the 2004 but if I push the shifter in Park hard it will then go up. Might just be the way our car is but try it next time."
A final person:
"I had a sensor that controls the top fail. The dealership quickly figured out what the problem was, but it took a while to figure out where on the car the sensor was located. They knew the general area but not the exact location. They were able to get the top back up, where it had to remain until the new sensor came in. Sensor replaced and not another problem."
Just trying to help, unless it's already resolved. If so let us know what was wrong, on your original thread, so others can benefit
