D
- 2
I Need Some Advice. My Friends Told Me I Should Replace All The Fluids In My O2 Bird Since It Sits In The Garage Most Of The Year. I Have 19k On It And Have Owned It Since New.
Took Their Advice And Now 2 Weeks Later Noticed A Puddle Of Trans Fluid In My Garage. Brought It Back And The Repair Shop (sts) Pulled Some Detail On Checking The Trans And Ran A Test Whereby We Started The Car And Opened A Small Bolt On Bottom Of Trans. It Is Supposed To Drain And When The Draining Stops, Trans Is Full. Well It Drained For Several Minutes When The Mechanic Finally Felt This Is Not Working Or The Trans Is Way Overfilled. In Any Event Took Car Home, About 2 Miles From Shop And Several Hours Later Noticed Another Large Puddle. The Fluid Is Coming Thru A Grommet In Front Of The Trans. I Understand The Seal Is In That Case. Anyone Have Any Experience With This Type Of Problem.
Thanks
Thanks
