- 25
- 1957
I have had the 57 about 4 months. After reading threads about the Pertronix 1281, and decided to buy one and mate it up with a Flame Thrower coil. Learned one lesson-Received new stuff, removed distributor cap...There is a Pertronix 1281!! However, it is hooked up to a stock coil, which is hooked up to the resister right next to it. The threads, and parts suppliers, led me to believe that the "hotter" coil was needed. However, maybe that's not really so, as the car is running. Anyway, the instructions for the 1281 and Flame Thrower contradict each other. The 1281's-keep the resister. The coil's-by pass it. The coil is 1.5 ohm, and I think that is what the resister is too.
So, can I just leave the wiring set up as is, and attach the Flame Thrower coil exactly as the current one? The reason I thought this might be necessary is there are two wires leading from the top connector on the resister (I assume power out). One goes to the carburetor, the other looks like it goes to an electric fan that has been installed on the front of the radiator. I felt if I by-pass the resistor, that would negatively impact the those hook-ups as it think it would cut off power to those two wires. I called tech support at Pertronix, they are closed until Monday. Thought I would try here. I guess I could leave well enough alone. Just thought there could be a benefit to the hotter coil. If I can hook it up just as the stock, that would be perfect. As you might tell, I am below amateur when it come to electrical issues.
