proper transmission fluid for my 64 tbird | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter thunder2010
thunder2010
thunder2010
12
I seem to be low on tranny fluid and want to top it up what should I use, can you use one of the new synthetic ones?
This will probably generate a ton of responses, but an oil engineer told me that the closest fluid to Type A, Suffix A is Dextron. That is what I would use. The derivative I, II, III etc is not significant.
Ford type F was not release until 1967. The MOST correct fluid for your car is Type A Suffix A. That is a difficult spec to find currently. Dextron or Dextron II, II, IV, is the closest formula to the Type A Suffix A. However, anecdotal evidence would indicate that using Type F will do no harm.
Bought my 64 in 2005 and had engine rebuilt in 2006. Had transmission checked out and was told to use Type F trans fluid. I have used it ever since then and not a problem.
Type A was replaced by Type F and is still readily available from many manufacturers. I have never credible advice that another type of ATF can be used. Auto parts stores normally will have it or can get it and the Walmart store by me stocks multiple brands so you can choose between a house brand and a name brand depending upon your budget.
