ISO 1957 Holley carburator rebuild kit | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter DIAS
DIAS
Hy, where can I find a rebuild kit for a Holley carb list 1551? 6R1432-3
I live in Belgium.
Thanks in advance
Dirk
What you have is basically an early version of a Holley model 4160. The better carburetor repair kits come with enough different gaskets and parts to cover the various sub-models of the 4160.
This is the Holley page for carb kits for the 4160, you might do an open Google search with the Holley part numbers to find better prices at other retailers. Hope this Helps!
Curtis Morris
Springdale, Arkansas, USA
Hi M. Curtis,
Thanks for your reply. But if I want to buy a new carb, which type of Holley is the best to replace?
Dirk
Hi M. Curtis,
Dirk
Most folks will want to retain the original style carburetor, but most are worn out and can be a hassle. Right now I'm running a modern Holley list # 1850 on my '1957 t-bird, it's a universal 600 CFM carb that works fairly well. Honestly, most any of the 600 CFM Holley four-barrel carbs with vacuum secondaries can be made to work, with some tuning. You may have to go to an electric choke and make some changes to accommodate the vacuum advance for the distributor, but these are easy fixes.
Hi M. Curtis,
Dirk
The closest modern replacement is the Holley 0-8007 390 CFM Classic Holley Carburetor. The original carbs were about the same cfm rating. Lots of people go with a similar style 4160 series in a 450 cfm because they are a couple hundred cheaper for some reason. If you go much over 450 you are overdoing it for these low reving y-blocks.
Ok thanks for all the help.
I have rebuild my carb en it works fine. I have only to check the correct working off the secundair barrels.
Dirk.
