J
Julie Butler
UPDATE EMAIL ADDRESS
Thought all of you might be interested in knowing the brakes went out on my 2002 t-bird. Going up hill at about 50 miles per hour and knowing that there was a stop light at the top, I let off the gas and at about 150 feet from the top of the hill I began to apply the brakes. Thought it was my imagination that the brakes felt mushy and did not respond in the normal way. When the brakes finally caught I was at the top of the hill about 10 feet from the stop light. I did manage to get the car stopped at the light and looked down at the floor and the brake pedal was on the floor. When the light changed, i gave it a small amount of gas and got thru the light and coasted into a parking lot. The dealership I purchased my car from sent a tow truck. I received the usual crap that I get from my dealership....."We will take a look at it and of course it will be covered under warranty". To make a very long story short..the mechanic called and said the brake fluid was corroded and he would order a new master cylinder and drain the fluid and it would be ok to pick up the next day. ..well, 9 days later I finally got my car back. They tried for three days to get the brake fluid out and could not. They said..."Never seen anything like it!". It took several calls from them to the Ford hotline to figure how to drain the fluid and clean out the lines. Ford hot line had them order and install another new master cylinder and then try bleeding the lines , one line at a time. No luck again! Finally after consulting with the hot line again they ordered a hydrolic pump which enabled them to finally bleed and clean out the lines. Two master cylinders and one hydrolic pump and countess mechanic hours later I got my car back. I am furious at Ford and I let them know it. I could have lost my life or killed someone else trying to get my car stopped. The dealership manager told me the brake fluid has problably been corroded since I drove my car off the showroom floor. There is no excuse for this, my car had only 10,000 miles on it. If I didn't love this car so much it would be sitting out on the street with a "For Sale" sign on it!
End of story....hope none of you have the same problem. Just want all of you to pay attention to your brakes and if at all they feel strange have them checked.
J F Butler
J F Butler
