Aftermarket Performance Parts Upgrades 2002 2003 2004 2005 Thunderbird | Page 3 | Ford Thunderbird forum club group 1955-2005 models
I was looking for some kind of tune to lower my Fan temp, I went to the SCT web page and there is no support for the t-bird anymore, Walmart happened to have the SCT X4 7015 on special last week and I decided to take a chance not been sure if it came with any pre-loaded tunes, it does come with just one the 93 octane tune
Has anyone here installed this non-branded cold air intake - cost is $70 as compared to the K&N at $350.
There are several positive reviews (Amazon) for this kit, but any feedback from forum members would be helpful.
I've seen in depth studies on CAI for Mustangs. It's effectively a novelty item and the performance increase is negligible. Some people claim it sounds better, but I think that is often psychological. I do have one on my Mustang.
With that said, my opinion is the chrome one clashes with the engine bay and looks out of place. I prefer keeping the original look the K&N has. https://amzn.to/3PL921K
I have a 2003 Tbird and I have a Borla exhaust system. It has a nice throaty sound, not overly loud and it gives the Bird a few more horsepower.
I have a 2004 and I have a Borla exhaust installed on mine. Took the shop less than 40 minutes to remove the stock exhaust (I kept it) and install the Borla exhaust. Sounds great and love the power, also installed the K&N CAI, it all really helped the performance.
I've had issues in the past with non-name brand intakes that either do nothing or actually lose some HP.
The reality is, without a computer tune+ CAI on a car like a Mustang, most CAI are just something people do as a hobby.
I suspect the drop in K&N filter is just as effective. Most people state the CAI Ads some sound.
All you need to unleash the power of your Thunderbird are three things!
1- Cold Air Intake 2003-2005 also for 2002
2- Exhaust 2003-2004-2005 ( says 2003 but will fit 2004 & 2005 per this post. 2002 only fits 02 model.
Also recommend replacing ignition coils since these are often bad! They are cheap now, so at the least have a set on hand!
You can do the first two and then the exhaust at a later time if you don't want to do them all at once. The tuner alone will also yield results.
A must have for any Ford Thunderbird owner! Click here to view the SCT Ford Thunderbird Tuner that works on 1996-2014 FORD Cars & Trucks.
Notes: X4 Power Flash Programmer; Pre-Loaded;Not Legal For Use/Sale In CA On Pollution Controlled Vehicle;, 93 Octane HP Increase +14 hp; Torque Increase +17 lbs./ft.~ Backs Up Stock Tune/Supports Custom Tuning~ Axle Ratio/Tire Size~ Holds Up To 10 Custom Tunes; Automatic On/Off/Sleep Mode~ Read And Clears DTC Codes; Built-In Performance Calculator~ High Speed Date Logging And Monitoring; User Adjustable Tuner Options~ Built-In Wifi For Easy Updates; User Adjustable Warning/Alerts~ Spark Modification By RPM/Wide Open Throttle Fuel~ Wide Open Throttle Shift Points/Shift Firmness Control/Cooling Fan~ Speed Limiter/RPM Limiter/Idle Adjustment/Traction Control
K&N 69-3520TP Typhoon Air Intake Kit is also a easy way to improve performance and gas mileage on the 2003-2005 Ford Thunderbird! Pays for itself over time! Click here to view on eBay or here on Amazon.
Ford Thunderbird BORLA Split-Rear Exit Cat-Back System With Single Round Rolled Angle-Cut Tip
Upgrade your Ford Thunderbird’s factor exhaust system to something truly amazing!
HP & Torque: 14 HP/ 18 ft lbs Torque.
Click here for 2003 2004 2005 Ford Thunderbird Cat-Back Borla Exhaust
Click here for 2002 Ford Thunderbird Cat-Back Borla Exhaust
All of the above have been installed in my 2003, love the sound
Just finished putting this together for my 02. Sourced parts from Amazon. Made cardboard templates to xfer to 1/6" Al sheet stock. Rivet together.
Rubber seal makes a good seal from engine heat and fresh air from behind the headlight/grill area has a direct shot to the filter. Looks and functions as good as the KN unit for $75 & hrs of thinking and fabricating.
The SCT tuners are almost always better than the factory programming and well worth the money and usually pay for themselves IMHO! Same goes for the cold air intake. Just the money you save on air filters makes the cold air intake worth it! The SCT is the best tuner, so spring for it, if you have the cash.
Does the cai make the engine run hot?
Any issues with overheating from the cai?
View attachment 30678View attachment 30679View attachment 30680View attachment 30681
That is a great mod. I come from the diesel pickup world where getting more and cooler air (more dense oxygen content) is important. Outside air, not underhood air.
Has anyone compared particulate micron and efficiency rating specs for the K&N, stock filter, and anything else? Usually a filter that passes more air is not filtering as well, if the square inches of filter media is the same. If the filter is physically larger than stock or the pleats are deeper, meaning there are more square inches of media, that is good.
Fluid and air filter manufacturers don't all provide micron and efficiency ratings. Both have to be looked at. For example, a 10 micron filter is designed to catch particles sized 10 microns and larger. But the efficiency is rarely or never 100%. If it is 95%, then five out of 100 particles larger than 10 microns will get by the filter. If 80%, 20 out of 100. The filter media is important. Some are dry and have to be replaced. Some like K&N are to be oiled and are reusable. There is no way to know what is happening unless a test lab tests the filter. Without doing any research, beware of a loud filter. It might not be filtering well.
