Shadrack
- 98
- 1964
Hey folks,
So I went out today to check up on my install of the pertronix ignition and the flamethrower coil. As many of you know my wiring is a bit hacked up so I wanted to make sure all was well. The red/green wire with a cap/boot goes on the positive side - it looks nasty. It measures 12+ volts when it is not on the coil - as soon as I attach it to the coil, it measures 5.88. I understand that I need this to be a switched 12 volt source. So, I went and looked under my dash and sure enough - a pink wire is still stuck in the back of my ignition switch - guess they left that alone.
So my question is this, what is the best way to bypass or replace this resistor wire? I have a starter button because they did a bypass on the neutral safety switch and so on - I am a little afraid to start messing with the ignition switch - but I understand that I need to bypass the pink wire or replace it with a normal wire that will supply 12 volts to the coil to take full advantage of my new ignition system.
I am sure this has been asked 100+ times, but since my car is a bit hacked up in the electrical department - I thought I would ask the experts before I start messing around.
Thanks so much in advance!
