64 Landau wipers on everytime starting car | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter Ezdarryl58
Ezdarryl58
14
Newbie every time i fire car up window wipers come on. I push lever to turn off but works its way back up ? Any ideas help
64 Landau is not a sufficient title. Your title should be a summary of your post. I will revise.
That makes sense. Are the on/off valves rebuildable or better to replace?
Hi there Darryl
On the '64 here's what the wiper motor beast looks like. I'm guessing the valve that Poppy Red is referring to is actuated by the lever at the top of the photo:
I've not actually dealt with one of these before so I'm spitballing here...
Doug
Thanks ill start with all.lines hoses then if not have my culprit
Unless your lines / hoses are leaking there is really no reason to take any of them apart. As Poppy Red said the problem is most likely the valve for switching wipers on/off. I think that is where you should check first.
