Pink T-Bird
- 52
- 1957
Trying to figure out 2 things to get my underhood wiring back to what it should be.
First - the oil pressure idiot light had been replaced with a gauge that uses a capillary tube by a prior owner. I have nothing against gauges, but I'm a belts and suspenders kind of guy and would like the light to work.
The light socket has power an a good bulb. A white wire that should go to the sending switch from the bulb socket routes up into the main harness and disappears. That seems stock/normal. It never comes out at the other end under the hood. I presume it was cut off and taped over in the underhood harness, Where should I look for it? Seems logical it would either be: with the wires that come from the firewall to the temperature sender and ignition resistor; or, be with the brake switch wires since they go down to almost the correct location. Before I start cutting off the black wire wrap I thought it would be a good idea to ask here if either of these are correct.
Second - the T&C radio works, but the volumatic wire is cut and coiled up at the radio. I can buy a replacement volumatic lead with the correct coil adapter, but how does that correctly route through the firewall to the coil?
Thanks!
Greg
Thanks!
Greg
