57 front brake line | Ford Thunderbird forum club group 1955-2005 models
57 front brake line
  • Thread starter Thread starter valhalla 4771
valhalla 4771
valhalla 4771
5
The brake line connection at the front wheel is kinda awkward to get a wrench on. Is there a special tool or should I be able to manage with your plain vanilla 5/8" open end?
Use flare nut wrenches. They wont strip brass fittings.
I'm installing the new front brake lines. Should there be a copper gasket at the connection at the front wheel? My parts manual shows one, but there was not one when I took off the old lines.
If you mean where the front brake hoses connect to the wheel cylinders, yes there should be a copper sealing washer. The washer needs to be minimum .062" thick in order to seal off at the wheel cylinder before the fitting bottoms out on the cone inside the wheel cylinder.
