1964 dual system master cylinder
BigClay
BigClay
Jun 14, 2018
Thought I’d share this. I recently converted my ‘64 Convertible to 4 wheel disc brakes. Today I added a “dual system” Master Cylinder. I tried the custom unit available from a TBird supplier that has the brake line fittings on the right side, but quickly noticed that if installed, I would never be able to remove the driver side valve cover. (Unacceptable!). In the attached picture, it’s the one in the middle. I wanted a early corvette master, but we all know they won’t fit with the under hood supports. (Because a corvette has 4 wheel discs). With little research and some minor modifications, I have made the perfect replacement! A 2006 Corvette master cylinder with the reservoir turned 90 degrees. Fabricated a hose connection to front port, everything fits, and it’s half the weight as stock.
Your post title should be a summary of what the post is about. Your title "1964 Disc Brake Conversion" has been revised.
