I have had this issue in mind since buying my 56 a few months ago. A friend ( a excellent commercial pilot and a natural mechanic ) has a 55. Have not found a discussion else where, so here is a newbies thinking. Real world guys please chip in..
First I agree with Dale, check the squirters to see if they are working. Be sure the bowel is full. Another hint of a weak accelerator is of course a stumble when you try to accelerate. Make sure the ignition system is strong. Fresh
coil, wires and plugs. These are old cars and need all the spark they can get to start and the antique starters take a lot of amperage.
Think I will change mine to a gear reduction starter when the budget allows.
Second,if the pump has a check valve ( do they all?) then the line from the pump to the Teapot
Holly should stay charged with fuel. Only evaporation over along period could empty it completely. Looking at the
Holly 4000
shop manual, and the position of the fuel line, it looks like it would be unlikely the
carb bowel would drain back much if the pump line is charged and held by the fuel pump check valve.
Lastly the line from the tank to the pump looks the most likely candidate for drain back. A in line check valve, cheap and readily available might service. But any opening pressure over say 1 lb invites interruption to the pump and cavitation with possible damage to the pump.
Summary: If the accel pump is healthy, and the fuel pump has a functioning check keeping the supply line and
carb bowel charged, that leaves the line between the tank and fuel pump to keep wet.
Conclusion: My bird will likely sit for weeks at a time and I do not relish a road side changing mechanical fuel pump. The advantages of a in line electric fuel pump, regulated to a about 3 psi would allow me to prime the tank to pump line , the pump body and
carb. With a DPDT switch I can prime, prime and/or run on the pump and provide a redundant pump so I can get home. Electric kits available from at least one tbird supplier or the round or square electric pumps widely available.
Look ward to hearing responses.
