shame on Ford for making that thermostat ordeal out of plastic.
Shame on you for thinking that's the same plastic a child's toy is made from. LOL FYI your car probably rolled off the line 23 years ago. The "plastic"
radiator in my 2004 Jeep TJ lasted 24 years before it cracked. Aluminum replacement Jeep
radiator last about 5 years. Everytime I hear someone bring up the "plastic" thing it amazes me. How you even seriously posting you are frustrated a 2+ decade old
part on a car that is exposed to 200+ degree heat needs replaced? What's on there is more durable than metal that will corrode.
Automotive plastic
thermostat housings are made of high-performance plastics like PA66 (Nylon 66) and PPA (Polyphthalamide), which are selected for their high-temperature resistance, rigidity, and resistance to moisture and chemicals. These materials are often reinforced with glass fibers to further enhance their durability and thermal stability.
• PA66 (Nylon 66): This is a very common material due to its excellent mechanical properties, including high-temperature resistance and thermal stress resistance. It is often sourced from major chemical companies like DuPont, LG, and BASF.
• PPA (Polyphthalamide): PPA is another type of plastic used for its high thermal stability and strength, making it suitable for the demanding environment under the hood.
• Glass-fiber reinforced polymers: Adding glass fibers to materials like PA66 and others increases their rigidity and overall performance.
• Lightweight and durable: Plastic housings are chosen because they are lighter than metal alternatives, which helps with fuel efficiency, without compromising on the necessary strength or thermal performance for the application. [1, 2, 3, 4]
[1]
https://www.x-rubberparts.com/application/automotive-product/custom-plastic-thermostat-housings/
[2]
https://thermansol.com/technologies/thermostat-housing-materials/
[3]
https://www.smartintlgroup.com/thermostat-housing-water-flange
[4]
https://www.aprios.com/insights/polybutylene-terephthalate-durable-resin-for-high-performance-uses
