- Mar 8, 2020
- 2004
Last night when using my right turn signal, the dash indicator started flashing very fast. I know that normally this is a signal that either the front or rear turn signal bulb has gone out. The dash also indicated Lamp Out. I pulled the rear taillight (the front turn was working) and examined the bulb, which looked like it had a complete filament; I figured that perhaps there was a minuscule gap in the filament I couldn't see, so I picked up a 2-pack of Sylvania LongLife 3156K bulbs. After installation, the bulb did not light, the dash still said Lamp Out, and dash indicators continued their frenzied flashing. Any thoughts? I'm dreading a FEM issue. Also, what a pain in the @$$ to get that rear taillight unit out just to get at the bulb. The long bolt which holds the nut on the outer housing is nearly impossible to reach, and you really need an extra-extended 11mm socket to get at it; my normal length extended 11mm was too short. I was fortunate to have an 11mm Gearwrech that I could maneuver onto the nut, but at times, I was only able to loosen it one tooth at a time. What should be a 5-minute job took 3 times as long. Wouldn't it be nice to gather the Retro Bird project engineers and ask them why they did certain things, and them make them attempt the repairs or removals that vex Bird owners so much? Back to the subject, though; any suggestions would be much appreciated. I should mention that I am not experiencing any of the other FEM related issues, but those might be heading my way...Thanks much.
