2003 p1703 brake switch out of range | Ford Thunderbird club group 1955-2005 T-Bird models
C
Hi there! I have 2003 THunderbird. Just replaced the PCM and had keys relearned where they flashed the PCM. It drives amazing! shifts amazing! and runs stead at 1.5 rpm at low speeds and 2.5 rmp at high speeds and does not fluctuate while driving, but now after the PCM replaced its popping up and E error code on the dash. I had it checked out on dealership scanners and its not throwing any transmission codes at all. only code is p1703 brake switch out of range. Could the problem be the new PCM?? Dealership and transmission shops are saying they dont recommend flushing transmisson fluid that was donein 2006 at around 25k miles it does now have 71k on it?? any suggestions?
I'm confused. If after replacing the PCM the car drives amazing, shifts amazing and runs steady at 1.5 rpm at low speeds and 2.5 rpm at high speeds, why do you want to flush the transmission fluid? Was the E error code displayed on the dash prior to replacing PCM? Why did you replace the PCM? Fault code P1703 indicates that during the self test the PCM detected that the brake switch is out of range. If the brake lights function properly, I would suspect that the PCM was damaged when they flashed the PCM.
The error code was not there when I replaced the PCM the original PCM was a complete failure no start multiple codes, sent it off for repair and they could not fix it, Ordered one from Flagship one and had the dealer relearn keys flash pcm. The new error code E and P1703 only started after the new PCM was installed, I did not flush transmission. but def suspect its the new PCM. Just filled out forms for the to replace PCM but I doubt they will cover the new key relearn 🙁 Thank you so much for the information!!
What was the final outcome?
You have probably figured we'd this issue by now, but apparently there is a section of the test where you have to use the brake pedal, if you don't, the test will tell you the switch doesn't work, but really it just had no way of knowing you had a switch, parking brake is not affected by this.
I think they missed a step in the reprogram I believe they have to step on the brakes at a certain point in the process of reprogramming also why any shop would tell you fluid done in 2006 is still good doesn’t make sense trannny fluid should be completely flushed and replaced every 30k miles or 5 years max, ( not a 5 quart dump and fill replace the full 12 quarts) is no such thing as lifetime transmission fluid.
