2003 A fuel rail location
J
May 25, 2021
Which side of the car is the "A" fuel pressure rail on?
Do you have to take off spark plug and ignition coil cover to get at it?
Pick up a service manual DVD if you are going to work on your own car, they are dirt cheap.
Your subject "2003 A fuel rail" has been updated to summarize your post. This will help you get more replies.
Fuel pressure rail A is on the passenger's side and contains the fuel temperature and fuel pressure sensors. The schrader valve is located on fuel pressure rail B.
"A" fuel rail is on the passenger side of the car. The pressure sensor for that rail is near the front top of the engine. You don't have to remove anything. But watch out! A small amount of fuel will shoot out when sensor is removed
