2002 T-Bird interior chrome door handles -chrome peeling off
Pete Higgins
Feb 25, 2018
I’m new to the forum today. I found lots of good information. Thanks
Does anybody know where I can get driver’s side chrome and passenger’s side chrome interior door handles for my 2002 T-Bird? The chrome on mine is peeling off and has resulted in some nasty cuts. Failing replacement availability, any solutions to the peeling chrome issue?
Feb 13, 2010
Pete,
I did notice that Krylon sells a spray can of chrome paint on Amazon and I think I have seen Dupli-color Chrome spray cans at some auto parts store. If you don't want to spray, you could always spray some into a cap or cup and use a brush. The Amazon site reviews tend to say it is more bright silver looking than chrome. I have not tried this but if you do try one of these please post your results.
Sue
Jun 7, 2015
02bird,
I picked up the wiring manual on EBay for $11.69 + $8.00 Economy Shipping. Thanks for the info.
Gus Gutz
Novel treatment of the chrome door handle. Not sure what he used, it looked like some kind of heat shrink chrome or maybe the heat was to activate a sticky backing. I wonder if it stays stuck or has sharp edges?
tjzzz21
Thanks for the idea. I think paint would wear off too fast so I probably won’t try that. My peeling chrome tends to curl at the edge and is as sharp as a razor blade. Unfortunately, I can’t seem to peel away the remaining chrome that’s still stuck.
I have the same problem with both door interior door handles. I figured that there wouldn't be an easy inexpensive fix So I haven't looked in to it. The peeling chrome on my driver's side is sharp as well.
Nov 21, 2017
I just got an idea. Just a suggestion: Try gluing silver leaf over the handles. Silver leaf is available from most craft stores such as Michaels and Hobby Lobby. And if you are skilled you might could do it without removing the handles. Just a suggestion I have no experience with this it's just an idea.
Pete Higgins
Feb 25, 2018
Sue & OREOCAT,
I went back and watched the video that Gus posted. I didn’t pick-up on it the first time but Chris Fix said he was using Chrome Vinyl Wrap. I haven’t tried it so I’m not sure how durable it would be but if my handles get bad enough I’ll probably give it a try. I have several heat guns and probably even a hair dryer would work. He peeled off the old chrome and cleaned the plastic surface with alcohol (I assume isopropyl?). In addition an X-Acto knife, squeegee and a micro fiber towel might be helpful. One technique to aid installation seems to be to pre-warm the surface where the vinyl wrap will be applied, and slightly warm the vinyl wrap itself.
Video’s on how to install vinyl wrap:
I checked out the Silver Leaf sheets @ Michaels. After comparing gluing the Silver Leaf and “Heat Shrinking” the vinyl, it looks like the adhesive backed vinyl would work better. From what I’ve read, a well-cared for vinyl wrap can last for 5-7 years. I just hope by then I’m still burning oxygen!
stretch
Jan 27, 2018
b4 i try that vinyl i bought something called' chroma metallic stripez ''today at auto zone.6bucks.its a roll of chrome foiltape with a peelable backing.after about 5 tries following the stupid 10 step direction process(using soapy water). i gave up and just peeled that backing off and put it on.used a hair dryer to make it more pliable. worked out the bumps.looks pretty good.if it dosent hold up ill try the vinyl wrap.u can get it on amazon.
donnyonee
Jan 30, 2019
ok maybe this won't look like oem but...
Home Depot sells a small roll of alum tape, 2" wide ?, used for heating ducts, its kinda polished looking and sticky on the back.
you only need to cover the vertical piece?
Mar 6, 2019
I had the same problem, and tried to get new handles, but you had to buy the whole door system which was more then I wanted to spend. So I bought some chrome tape and trimmed it to fit, wrapped the handles, and it still working 3 years later!
Jul 18, 2020
Has anyone been able to get inside door handles or know of a way to repair them?
For my 2002 I replaced driver side handle from village ford auto parts, they got it from a Ford storage facility and I had to pay extra for entrance during covid, local Ford dealer installed it and panel looks perfect. Good luck !
I might will post if possible
Latch assembly 3w6z76219a65ab my notes
Sep 20, 2021
I recently purchased an ‘03 T-Bird. I’ve noticed that the chrome is peeling off of the interior (plastic!) food handles. Is there a way to stop this peeling, so that I don’t have to replace the door handle?
Forum Moderator
Staff member
Mar 9, 2003
Read posts above.
medurham
Jul 19, 2020
My 2002 is doing the same thing. I was thinking of taking them to a powder coating shop as they have a chrome color and you get a smooth hard finish.
Jul 18, 2021
Mine was very sharp. But I just kept working on it. I got to a point where I just sanded the one on the passenger side that just would not peel off completely. So I had to use a little filler and sand it with 2000 grit sandpaper. After, I spray painted with sandable primer and used krylon semi- gloss. Hope this helps.
