2002 gauge cluster removal
1. Tilt the steering column to the lowest position and telescope (extend) the steering column to the farthest position.
2. Remove the instrument panel cluster finish panel.
3. Disconnect the battery ground cable.
4. Remove the screws and remove the steering column covers.
5. Remove the bolts and remove the hood latch release handle.
6. Remove the pin-type retainers and remove the instrument panel steering column cover.
7. Remove the screw and remove the floor heat duct.
8. Remove the bolts and remove the steering column reinforcement.
9. Loosen, but do not remove, the steering column nuts.
10. Remove the screws and remove the instrument cluster.
11. Disconnect the electrical connectors.
To avoid damaging the instrument cluster lens, place a protective cloth over the upper steering column before removing the instrument cluster.
gauge cluster removal sequence advice please ?
good morning, seeking guidance on sequence of dash gauge removal ?.. Thanks !
