edward301
- Nov 3, 2007
- 2002
Have been having issues with my high mileage 2002 T Bird not wanting to start unless I start it every few days.
Today I decided to figure out what the problem was. Had voltage so figured it was the pump motor itself. The
battery is four years old, so giving it a good charge to see where the standing voltage is.
I put the charger on at 30 amp charging rate, gave it ten minutes to charge up, and car immediately started.
What I figure is pump motor is slowing getting weak due to age, and unless your battery is well charged with
good voltage the pump motor does not have the starting torque needed to get the pump turning. Did not
blow fuses, simply would not start pumping without enough voltage.
Will see what my battery standing voltage tomorrow. I now agree with others these T Birds are sensitive to
the correct voltage.
