2002 A/C Discharging leak | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter rexcsmith
R
rexcsmith
2
I've had to recharge my A/C a couple of times in the past month. It apparently has a leak. Where are the obvious places to look for leaks? Is there a map of connections?
the only repeat place I have had was the manifold mainline hose. That's the one bolts the compressor with 2 hoses the big one on the bottom leak both times at the double O ring connection under the right side of the radiator. That connection you will need a special tool for A/C O rings. I had the use a hammer to get it to move. But I am 75 and don't have the strength I once had.
Thanks for the input. BTW Flash, I'm also 75 🙂. I bought a can of stop leak with dye in it, but I'm not sure it's a good idea. Can the stop leak gum up the works?
You will get mixed answers here. I've used a specific one on my Jeep and it worked for a year. It's obviously better to find the problem. Stop leak only works on small leaks as well and results vary by brand.
Stop leak is not good for AC
systems.
Well, as I said in my post above, knew this was coming. Notice he didn't say, I used stop leak and it killed my compressor. Just general information he's probably heard or been told.
There is nothing scientific I've seen to support this, and I've used it in an old Jeep and millions of people use it and while there are product reviews saying it didn't stop the leak or it returne, I'ven ever read one that said it caused damage. Obviously if it could be proven to cause harm, the manufacturer would be liable & the product would cease to exist eventually.
PS it's dye, not die.
