AJW
- 22
- 2005
Note: This feature may not be available in some browsers.
We're glad you found us via a search engine! Right now, you can join our club absolutely free and unlock member only features like the site search! This notice only appears once! It only takes 30 seconds to register, and we would love to have you as part of the World's largest Thunderbird Forum/Club! Click here to continue
Grounds are switched on off. Plus 12v always hot on Tbird lights. All of them.I’m trying to wire a rear camera to a 2005 Thunderbird. I intend to put a relay in the truck but I can’t determine what wire is the reverse light feed to go to the relay. When I put a test light to the reverse light wires they both have power. Both the black and red and the pink and blue. I changed the radio to a JVC apple play. Everything works, the subwoofer, center console speakers, even the steering wheel volume controls. The is the final piece of this project. Any ideas, I think I’m missing something!
All I can tell you is from what my installer was saying he said that the thunderbird was weird things that should have been positive were negative and things that were negative were positive once he hooked the power to the camera the camera would not work after hours of him scratching his head he decided to switch the wires to the camera and then viola camera started working. Sorry but this is all I got on that I hope that it helps. We ran into the same issue while installing the remote start as well best advice on that is to find a person that has not done one before or they will want to charge insane money because it is so difficult and a real pain. I found an installer that said he as good and reviews said he was good and he said he’s never installed one on a bird before but was like how hard can it be he charged me only 150 for basic install quoted price upfront took him over 9 hours to actually finish and make it work lolI’m trying to wire a rear camera to a 2005 Thunderbird. I intend to put a relay in the truck but I can’t determine what wire is the reverse light feed to go to the relay. When I put a test light to the reverse light wires they both have power. Both the black and red and the pink and blue. I changed the radio to a JVC apple play. Everything works, the subwoofer, center console speakers, even the steering wheel volume controls. The is the final piece of this project. Any ideas, I think I’m missing something!
I can tell you that won't work on a Kenwood, the backup light signal is expected to go high (+12V) by the radio to invoke the camera image on the radio screen, our TBird's signal goes low instead; hence the need for the relay as discussed in prior posts.Fairly easy/simple connections, running the wires to the back is a pain though.
