Wheel spacer for 1966 tbird | Ford Thunderbird forum club group 1955-2005 models
6
I have a thunderbird 1966 and bought aftermarket wheels for it. The front wheels don’t have the right offset so they don’t clear the front calipers. I have not been able to find aftermarket spacers that have the correct size hub hole in the middle. Does anyone know where I can get a set of spacers that will fit? 3/4” should do it. They would also need to have lugs as the OEM aren’t long enough with the new spacer in. Thanks in advance if you could give some insight/help.
I don't know where you would find 3/4 inch spacers, that seems like a lot. However longer studs are available for you hubs, check your local speed shop. ( Drag racing rules require long studs.
