Water pump pulley removal 1956 Thunderbird | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter RichW
RichW
4
Hey Guys,
Trying to get the water pump pulley off. Manual says remove the 4 fan bolts, take off fan and pulley. I can’t get the pulley off. Is this usually difficult to remove or have I missed something?
Thanks
Hey Guys,
Thanks
as long as you have the bolts and belt removed, it should come right off. might try gently tapping on it with a plastic mallet or shoot some pb blaster in the center where the waterpump shaft sticks thru it and letting it set for awhile then tap with mallet
Thanks Tbird57. I will give this a go. This isn’t any chance that there is a one piece pulley that is pressed onto the water pump shaft by any chance?
