twstnshout
- 4
- 1957
I’m using a passenger car 312 in my 57 restoration. I’ve corrected all the various differences. I installed the larger crank damper. My question is does the timing pointer on an original tbird motor extend all the way out to the timing marks on the inside pulley? Also what is the correct depth or height of the water pump pulley. The generator pulley lines up with both pulleys as does the crank and water pump pulley.
