E
Erict
UPDATE EMAIL ADDRESS
I recently posted a comment/question regarding the Traction control button and the fact that it would always reset to the ON postion.
I consider this an anoying thing.
Well one evening on an outing on my sailboat with some freinds, we got to talking about this.
Well one of my freinds suggested I try depressing the button permanently and see if this would solve the problem.
Well it DOES!!!!
If you depress the traction control button and keep it depressed all the way through the ignition cycle and the electronic check the car goes through (Airbag, ABS and Traction control), what you endup with is a Traction control "OFF" position.
I am now looking at a descrete way to wedge the button in the depressed position.
I think the flat part of a tie rap in a black color so it will not show will do the trick. I need to slip it between the car trim on both sides of the button and the tention built into the plastic should be enough to hold the button in the depressed position.
From an esthetic point of view, it should not show.
Well it DOES!!!!
