Replacing Upper control arm bushings removal on a 1955 Bird | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter JDJ
J
18
Does anyone have any information on how to remove and replace the bushings on my 1955 Thunderbird?
I recently did mine. A little tricky as all the bushings appear similar. I had access to a hydraulic press and various things to press with which simplified the process.
Best if you have a manual as the bushings are alternately installed fron the inner and outer side of the upper control arm as I recall. And be sure to note how far in they need to go. Take pictures as a visual reminder!
Some of the auto stores may have loaner tools to do this as well or consider taking them to a shop. I was quoted two hrs. for this work. It took me, inexperienced, three hrs.
Good luck.
Art
Good luck.
Art
