Original 56 312 with vapor lock symptoms | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter mc56bird
mc56bird
My original unrestored 312 has always started right up, even in this heat, whether sitting 5 minutes or two hours. Suddenly and consistently now, it just cranks with no fire. This started a few days ago, and has happened 4 times in a row. Starting symptoms when cold are uneffected. I got it to fire up each time by pulling the manual choke out full, obviously quickly pushing it back in. No fuel smoke or other flooding symptoms. Once started, it ran great as it always has, including giving it some juice to see if it was starving for fuel, which did not happen. Sort of a vapor lock issue similar to my old Ford flathead. Everything appears fine visually. Any suggestions on where to begin my diagnosis? THANKS!!!
Check your fuel lines by your exhaust if to close you will go to vapor lock had a problem with my 57 312
Similar threads
