oil temp? 2003 t-bird | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter peavid
This is weird...after a few days in the cold garage, my '03 T-Bird w/45,000 miles wouldn't start. It just whined, without firing. After I determined that the battery was charged, but still wouldn't crank the motor, I had to have it towed to my mechanic.
He was able to get it started by flooring the gas...but it smoked like crazy for a few seconds, then ran normally. He kept it for a few days to see if it would repeat the event; but it ran fine from then on. He said that the plugs had been fouled by engine oil; the amount of oil in the cylinders temporarily raised the compression so much that the starter wouldn't turn it over. The car's computer gave a high oil temperature reading; but after it started, the code was cleared.
We couldn't figure out how oil got in the cylinders; if it had really been a broken ring or valve guide it would still smoke. I'm concerned that the problem could recur. Any ideas?😱
This is something I haven't heard before. Please keep us tuned in if you have other issues of this kind or find resolution. Thanks for posting it, and good luck!
Not sure how and why the computer showed a high oil temp. Seems to me that if temps got hot, then it would show high oil and water temps!! Maybe I mis-understood mechanic.
