I want to install an ignition switch in my '55 6 volt. The wires are just hanging loose under the dash. All different colors. The back of the switch has 4 screws, ignition. Batt. Start. Acc. Which color wires go to each connector
According to the 1955
wiring diagram:
On the Batt or B terminal – Yellow wire from the B terminal of the headlight switch
On the Start or S terminal – Red/blue wire going to the starter solenoid
On the Ignition or C terminal – Red/green wire going to the Batt terminal of the ignition
coil
Black/green wire going to the charge indicator lamp
Black/green wire going to the oil pressure indicator lamp
On the Acc or A terminal – Black/green wire going to fuel gauge
Orange/yellow wire going to the 9
amp fuse for the turn signal
flasher
Brown wire going to the 20
amp fuse for the blower switch
Black wire going to the 14
amp fuse for the radio
Red wire going to the 30 amp circuit breaker for the power seat switch
Black wire going to the 15
amp fuse for the overdrive relay (if equipped)
Red wire going to the 15 amp circuit breaker for the power windows
