EGR valve - how hard to change? 2004 3.9 V8 | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter JW in Dixie
JW in Dixie
JW in Dixie
205
Engine lite again so I raised the hood and took a look at the valve. Looks simple except for a tube connection that requires a +- 1" open end wrench, which I don't have. Probably metric. Anyone done one? Thx
Its a bit of a job but it will require two people, at least it did when I did it. There isn't much clearance but it can be done. I had to run out to Home Depot to buy a wrench as well. Good luck.
Thanks. What size is that wrench? Found a video of the procedure online:
Watched the video again and he used a 1-1/6" wrench. Yeah, like every set comes with one of those. Reminds me of the 21/32" required for the flat-head Ford V-8 rod nuts.
Got 'er done by myself. It is just barely doable, space-wise. Borrowed a wrench from the local railroad shop. On the final tighten the wrench broke a plastic tube fitting on another gadget that they put in the path, assuring that a do-it-yourselfer would surely break it off. The tube piece disappeared into oblivion, of course, so I fabbed one and attached it with hot glue. Started the motor and the danged check engine light is still on. Will drive and use the code reader to try to clear it.
It's always something. 🙁
