B
BigBird28
- 0
- 1973
Boy have I been busy! After struggling to get the timing right after installation of MSD ignition, I decided to tear the front of the engine down and do the timing chain. I have everything off now except the harmonic balancer and timing cover.
I understand that the 1973 460s had a 4 degree factory retard at the cam. I'd like to get rid of that and time it straight up but just want to make sure that my plan and research is accurate before I go for it.
My plan is to manually crank the engine to TDC. Once at TDC, remove the harmonic balancer and timing cover. I'll then remove the old timing chain.
I'm then thinking that next I fit the new crank gear onto the shaft in the keyway and line up the new cam gear to the 4 degree retard keyway slot. Then I'll slide the cam gear off and rotate the cam so the it lines up with the tdc 0 degree keyway on the cam gear. Thus this will advance the cam 4 degrees from factory to a straight up timing.
Do I have this right? I really want to be careful as to not destroy the engine and bend valves.
