66 TBird wiring help | Ford Thunderbird forum club group 1955-2005 models
T
Hope someone can help. right behind the distributor and on the top of the engine block there is a connection nipple with a red with white wire coming off. Does anyone know what the wire is ???
Thanks, Tom
My first thought was that location (rear of the engine, top of the block) is the oil sending unit. Then I looked at some wiring diagrams for the '66 Thunderbird. There is a red / white wire that shows in the transistorized ignition and it goes from the amplifier (through a harness) to the ballast resistor. Could that be the wire you are talking about? A picture would also be helpful if you could post it.
Thanks, Tom
The small threaded "hub" behind the distributor is the temp sending unit. It should have a red wire with a white stripe. The oil pressure sending unit should have a white wire with a red stripe.
