64 bird removal map light wiper clock assembly | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter Ezdarryl58
Ezdarryl58
14
Cant seem to figure out how to get map light wiper assembly out to check low fuel emergency flasher light bulbs door ajar works but thats it .cant find anything pertinent in shop.manuel
The right angle arms are a separate part from the arms that come out of the module. They are held together with a Phillips screw. Once the are removed, the arms can slide out of the module.
Yes the wiper/washer and vent controls have screws in the handles that come out. This allows you to take off the cover. Be careful and dont let it drop as the wiring will be all thats holding it once you have all the screws out and those wires arent that long. Wouldnt want to break one.
Ok replacing low fuel and hazard light bulbs . But does anyone know where the red wire in my picture conects to im not finding another loose wire and its red si im assuming its some form of hot wire if any ideas im definitely all for hearing them. Found this after vacuuming out giant field mouse best
On a 1965 there are four screws near lamps two per side this will allow you to drop it low enough to access swtches, clock and light switch.
Similar threads
