L
lennard
- 4
- 1976
Hello everyone,
I have recently imported a 76 Thunderbird to Germany... the car is in pretty good shape, but there are a few bits and bobs that need fixing, including the oil pressure / overheat indicator light on the dash. As I understand it the light should come on, when I switch the ignition on, however it does not. I have already removed the dash to check the bulb, and the bulb is good - there is no voltage at the bulb socket with ignition on.
Now i have a Haynes workshop manual with circuit diagrams, but the indicator bulb ist not represented there, so I cant figure out which components tie into it and where to check for broken wires/corroded contacts/the like...
The original owners manual tells me that fuse 16 is also responsible for this light, but the fuse is good...
So my question now is, if anyone here can tell me how the engine light curcuit works, where the contacts are and which components might need checking.
It might seem like a very minor problem, but since I cant readily get replacement parts where I am, let alone a whole engine, I really dont want to kill it by being negligent on something like this...
Well, thanks for taking a look,
Lennard
Lennard
