valhalla 4771
- 5
- 1957
Actually I'm still trying to drop the oil pan. The shop manual says to "Disconnect the oil pump inlet tube at the oil pump, then remove the "O" ring. Remove oil pan retainer screws, then remove oil pan". I've unscrewed the retainer nut connecting the tube to the oil pump, but that is as far as can get. The tube appears to extend further into the pump and there is no wiggle room and I can't see the O ring. The oil pan won't move because the tube is holding it firm. The retainer nut holding the tube to the oil pan is on very very tight and I don't want to add force unless I'm sure this is the correct action. I've loosened the two bolts on the oil pump closest to the oil pan, but the pump doesn't want to move. I'm stuck! Help!
