Y-8
- 12
- 1955
I have installed a new brake system from the master cylinder to the wheel cylinders and everything in between. I have manual brakes, I do not have a power booster.
I am wondering if I can gravity bleed the entire system - My question is concerning the master cylinder, will it bleed properly by simply allowing gravity to push the air out or is it necessary to manually bleed the master cylinder first? I am choosing to gravity feed because the entire system is dry and it seems that it will use less fluid, mix less air into the fluid and take less fluid overall. It will take a lot longer but is gentler on the system.
