2005 Original Tires safe? | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter soupy07
S
my 2005 bird has the original Michelin tires. 24500miles. should I replace them? one has a little cracking otherwise they look normal and very rarely need air. Maybe something in a raised white letter??
Moderator Note: The National Highway Traffic Safety Administration (NHTSA) and official manufacturers suggest a tire is only 100% safe to use until it turns 5-6 years old.
Rubber products start to slowly deteriorate shortly after they are manufactured. Cracks in a tire's rubber begin to develop over time, appearing on the surface and inside the tire as well. This cracking can eventually cause the steel belts in the tread to separate from the rest of the tire. Improper maintenance and heat accelerate the process. Many automakers, including Ford tell owners to replace tires six years after their production date, regardless of tread life. Tire manufacturers such as Continental and Michelin say a tire can last up to 10 years provided you get annual tire inspections after the fifth year.
I changed mine on the 2014 after seven years and 21000 miles. I am dubious that they needed changing in my low ozone climate. Consider that cars have thousands of rubber bits and pieces. I would expect rubber scientists to know how by now to make long life rubber products so long as they are not physically worn out. I did change the spare at the same time.
Your tires are 17 years old I would replace if you do and highway driving, new tires are cheaper than fenders getting damaged from tire coming apart!:
I replaced tires on my 2002 in 2012 with only 18,000 miles on them, I will be replacing them again this summer, with only 6,000 miles on them!!! I have 24600 miles on the car!!!
The only thing between you and the road is tires. Is it a good choice to drive on tires that old going 70 MPH?
Definitely they should be replaced.
16 year old tires are about as safe as gas station sushi...
"Looking normal" has nothing to do with it.
Many tire shops won't even rotate/balance tires 10 year old or older as they are considered safety hazards.
Regardelss of mileage, if you drive the car, replace them for safety and peace of mind.
Think of it as insurance, which you pay for and hope you never need. Cheers
Tire shops have a vested interest in selling new tires. Those who work there may be more useful if they can point out visual defects that actually justify tire replacement.
When cars are driven few miles annually the tires sit and get flat spots and also the rubber gets hard. You don't notice the ride deterioration as it is gradual over the years. When you change those out of date tires for new ones you should notice improved ride handling, and traction. I have a 2003 Thunderbird that I purchased recently and it had the original Michelin tires on it and rode horrible... So bad I almost did not buy the car. The owner said it was the tires and they were original and needed to be replaced. I changed the tires and what a difference! I asked why he did not change the tires and he said he just collected cars and did not drive them often. He had a 2002, 2003 2004, 2005 in mint condition in his collection! He got me to thinking about tires and I checked the tires on my low mileage 2004 Hummer H2 and I had 3 original tires two on the ground and one as the spare. I changed them and cant believe the difference that the new tires made in vehicle enjoyment and safety! Now I am tire poor, but happy and safe so change those tires.
The 2003 I just purchased from my MIL had the original tires on it when I got it last month. The tires looked perfect since the car had 10,700 miles on it. The date code on the tires was from the 42nd week of 2002. The first thing I did was drive to Discount Tire to get a new set put on. I would change them if they are 8-10 yrs old. I had one on my Trans Am come apart and trash my front fender.
Might want to check the spare - there have been some reports of the exploding and doing damage to the trunk area.
Wise man changes his tires three to five years depending on the area one lives.. visible cracking in the sidewall is an indication that the ozone in the air has attacked the rubber.. what is not always visible is the cracking in the tread at the bottom of the tread sipes, this rubber covers the belts in radial tires and is generally .05 inches thick. When this rubber cracks, moisture can inter and potentially rust the the wire belts, and then failure can occur. Some tire manufactures utilize an antiozant in their sidewall and tread rubber compounds to retard ozone cracking.
Every 3 years on a garaged toy that gets driven 3,000 miles per year. ? Can't see that...
Maybe 5-6 years. BTW some tires have become hard to get (supply chain ?) I recently
tried to buy some Hankooks for another car and nobody had them.
