B
- Aug 14, 2019
- 2005
If anyone has a hard top that the rear latch doesn't pull it down enough to firmly seal or the top makes noise over bumps there is a easy fix that doesn't involve cutting welds on the 2 post nuts also the rear defroster can be repaired if it is split in half when the latch is removed. If anyone is interested, I will post what I did to correct mine. Not sure if this is a no topic at this point for folks.
