S
Sharps40
- 45
- 2003
Moderator note: See this thread for a parts list.
forums.fordthunderbirdforum.com
I'll type it up first, then add photos, probably take a couple of posts. Then you'll have it all in three posts and not have to hunt through many comments for the steps.
I started chasing down annoying clicks and clunks in my 71K mile Thunderbird. This classy car ought to be clunk free.
First one is resolved two weeks back. New tires to replace the 12-year-old dry rotted hard as a rock and shaking Falkens. Added a front and rear alignment for $75 and no more shimmy shaking thumpy bumping down the highway.
The second one resolved today. The third one is yet to be located but sounds like it's under the third brake light.
To the second one.....a light click in the rear suspension. Everything on the rear checks tight and unrotted, except the sway bar links.
Got mine from Detroit Axle through Amazon.
-Click here for Rear.
-Click here for front and Rear (Mod updated)
Though offshore made, you can see they are substantially heavier construction in the shaft and have zerk fittings. Mine came greased, but now I can give them a shot of lube at each tire rotation. For me, that will be every 10K miles with the oil (full synthetic) and filter change.
Jacked up the car with the floor jack in the rear spot, added a jack stand under the suspension, took the wheel off, cleaned the lug nut threads and the lug stud threads. Brakes look good but are the cheaper dusty type, I'll get to replacing them later.
Hit the upper and lower nut with PB blaster, your uppers may or may not have a protective cap over the nut. Mine did on one side, it broke on removal, it did not have an upper cap on the opposite side.
No room for a buzz wrench on the lower nut but on the top nut there is. Buzz it off. If it won't buzz off, just keep at it till you see bubbles coming out from under the nut, then switch to wrenches and turn the nut off the upper stud.
Use wrenches to turn the lower nut off its stud and remove the sway bar link. Where I positioned my jack stand (near the bushing) there was no tension or compression in the sway bar so everything was slip in and slip out.
Install the new link. The nuts that came with it are the light interference thread type and have a built in scalloped washer. No lock tite needed, just tighten them up. I went to 40 ft lbs for the small diameter studs.
Reinstall the rear wheel, lube the lug studs if thats your wont....I do. Saves grief later, more even torque and they don't come loose nor gall.
Of the two links, the passenger side was worn to the point of simply flopping at the joint. The drivers side was only slightly tighter. Plus, all the rubber was rotted away on both.
Took it for a ride, no more suspension noise, so, now I can rip out the trunk liners and top well liner and find that last clickclunk, after I replace the burned out front drivers light bulb.....
Ford Thunderbird Sway Bars & Tie Rods 2002 2003 2004 2005
ECONOMY PART $: 2002-2005 Front Sway Bar set only. Click here to order on Amazon 2002-2005 Front & Rear Sway Bar End Links Replacement for 2002-2005 Ford Thunderbird Click here to order on Amazon. 2002- Detroit Axle Complete Power Steering Rack & Pinion Assembly + All 4 Inner & Outer Tie Rod...
