2003 Engine and Transmission Differences | Ford Thunderbird forum club group 1955-2005 models
  • Thread starter Thread starter HKS
HKS
29
The 2003 engine makes 28 more horsepower at 6000rpm (2002 has 252HP at 6100rpm). Torque is 286 lb/ft at 4000 rpm (2002 is 267 at 4300 rpm).
The 2003 also gets better gas mileage. I first thought that it was all due to the Variable Valve Timing.
I noticed transmission differences also.
Second gear is now 2.29-1 (2002 is 2.41-1). More zip in second gear.
Fift gear (overdrive) is now .71-1(2002 is .75-1) giving more overdrive and helping fuel economy.
The engine actually produces more horsepower and torque at a lower RPM and is able to meet stringent California 2003 emission standards. Nice touch. The 2003 takes a great leap into the future of engine design.
HKS
The 2003 also has an electronic throttle, that helps the mileage since the computer operates the engine instead of the drivers foot. I heard that this needs a little more work and is causing the delayed start of 2003 LS and t-bird production.
Ron
VIN #7729, seq.#7505, blue premium,
partial blue interior, no top, Louisville Ky.
In airplanes that is called FLY-BY-WIRE.
The airplanes I worked on(A4C)had 2 hydraulic systems plus cables used to control the plane. You have to have faith when you fly-by-wire.
HKS
It Wixon on a T-Bird line tour we saw a 03 prototype with the new engine and transmission outside the plant. The driver a yung engineer with 'drive line group' sait it felt much faster than the 02 and the 28 HP was conservative. The transmission has a + and minus gate next to the main N..R..Drive 5 Drive 4 gate. If you use this gate it will upshift or downshift by pushing the shift lever slightly to the + or minus. Really neat!
Looking under the hood the air intake is different and the plastic cover has a larger TBird and V8 logo than the 02.
