2002 water pump gasket thickness | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Zorro
Zorro
Zorro
Just took off the original water pump on my '02 and the gasket was a thick red one. The gasket that came with the new water pump is a very thin cardboard gasket. Should I try to find a thicker gasket, or will the cardboard one suffice? I had to order all new bolts for the water pump as most were rusted out. Thoughts??
OK I ordered a new water pump gasket and it looks like it is mostly metal (?!). Paid $24 and it leaks...don't want to over tighten the bolts (OK I already did that and broke one). Should I go back to the one supplied with the water pump? Sharps and Anthony C--thoughts?
Do bolts enter the water jacket? If so seal the threads. I have never seen a metal water seal, may need a skim coat of sealer.
