2002 retro hardtop removal electric defrost connection | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter gcd55
The connection for the rear window defogger is on the underside of the passenger side locking lever. Just rotate the locking levers rearward and apply slight upward force to the top.
The picture Doug posted is good. It is the hardtop side. On 2002 on the car side it is a black plastic doughnut that is cliped into place and the post goes through it. It has matching contacts for the hardtop side. Many times the car side part, or the sister part on the other side gets broken from putting the hardtop back on.
Forgot to add if either or both parts on the car are missing, the top will rattle, not fit properly.
The lower "female" connector popped out on mine after 2 or 3 removals. Seems to be an overall bad design unless you're especially careful with it.
It can be carefully taped in place to help retain it my original was not brittle can’t imagine breaking it with the locating pin.i drop my top on foam blocks instead of blindly bouncing the pins on the paint.those pins should have been made from a synthetic material
