Eskertl
- 3
- 2002
Great and informative forum. New user. Got my second TBird after a 50 year hiatus. Problem(?): turning the ignition key to position 4 the headlights flash 5 times. Vehicle starts without problem. The theft indicator is on top of the instrument panel. it has never flashed every 2 seconds when the ignition is in the OFF position. With the key in the ignition in the ON position the indicator has never glowed for three seconds. I received only one key and one fob with the sale last October 2021. I had two keys and fobs cut and programmed at the local FORD Dealer. I thought the Passive anti theft system would respond when I unlocked the vehicle with the fob, inserted the key to Accessory, set the driver's window to half down position then removed the key, exited the vehicle and locked the vehicle with the fob. I reached though the window and opened the door with the inner door handle. No response. Question: is the PATS inoperable, non-functioning? Any thoughts or advice would be much appreciated.
