W
- 3
- 2002
I had neglected to check my coolant level for a while and saw that the temperature gauge would go the 3/4 mark and then almost immediately fall back to the 1/2 position. I added fluid about a quart, and carefully bled the system. Today, after about 10 minutes after I started, and the indicator had been normal for about 5 minutes, it went up and the red warning light went on. I pulled to the side of the road but before I could turn the car off the red light goes off and the indicator goes to normal. Five minutes later the same thing happens. I head for home 10 minutes away and indicator stays at normal.
I understand that the 2002 water pump is hydraulic - is mine failing? (70,000 miles on the car). Any point in flushing the pump system? No signs of a leak - the coolant level has stayed constant through this. I may have overfilled the coolant - it’s up to the rib in the overflow tank but I double checked the cap and it seems to be functioning. Are there ways to determine if the pump is working correctly?
