2002 No power, alternator problem? | Page 2 | Ford Thunderbird club group 1955-2005 T-Bird models
  • Thread starter Thread starter Netconn
Have them check the FEM. My radio and clock issues were fixed when it was replaced.
After wrestling a new alternator back under the bird I'm happy to report that it's charging again. The only thing I had to do was reset the windows and reset the radio stations. I think the government should pass a law stating all auto designers must work on the cars they design before unleashing these things onto the public.
So, Murphy's Law. I just listed my 2002 T-bird for sale. It's been perfect for years... And now there seems to be an alternator problem. I was getting the battery light for a few minutes, every so often when I start the car in the morning, it goes off and all seems fine. Yesterday I start the car, no battery light, it was dark so I had the headlights, radio, heater on. I'm driving down the road and the ABS & traction lights come on, next the radio shuts off, next the heater shuts off, my radar detector says "Low Battery" and it shuts off. Headlights dim and engine not running great, but running. I keep driving to get to my destination as best I can. About 5 minutes into this everything comes back on, headlights bright and the ABS & traction lights are off.. All is well again.. I park the car. I drive the car back home later last night and the same thing happened.
I'm assuming the alternator has failed and is intermittent. But I don't see the battery light come on at all. I also assume the computers shut down everything when the battery voltage drops below a set voltage.
Anyone seen this happen?
I had a condition were the alt lamp would would go on for a few minutes. I hooked up my Fluke meter to the cigar lighter and the next time it happened the Fluke read 14V and the Alt light was on. I assumed that the connection from the Alt to the control module was intermittent. There is a small plug on the Alt which I removed and could see no corrosion on the plug or socket. I sprayed the socket and plug with "Deox" which is Ford approved and the problem has not returned. I believe the issue was "White Corrosion" which happens between tinned plated surfaces under high vibration conditions.
Using a DC volt meter, check the voltage across your battery (plus to minus) with engine running. It should read between 14.5 to 12.5 volts if the alternator is working correctly and the "v" belt is tight. More than likely it would be one of those items.
